Getting A Fh Code, Checked Water Hoses They Are Straight And And Screens Are Clean, Water Valves Are On Allthe Way On.
A good possibility is the flowmeter. It is not an expensive part, nor hard to change out, so I would try it and see if that fixes your problem. Here is the part. Part number: AP4310720
Let us know how it turns out because others have had this problem and the flow meter has fixed it.
