i am getting an fh code and was told by whirlpool that it wasnt getting water but it is - is there a quick fix or do i need to replace valve or is there a way to test the valve since the water is flowing
Thanks to this forum I got my washer working again. We moved into a new house and had to move the reconnect washer and dryer to have the doors open correctly. We inadvertently forgot to turn on the water and saw the F H flashing and heard beeping. Then the door was stuck on locked and couldn't stop it. We flipped the breaker a few times, didn't work so then left it off for 20 minutes and turned dial to drain spin and selected no spin. Time changed to 02 and at the end machine turned off and unlocked!!!
I was able to start a new load after turning breaker back on and turning on water. WOOOHOOO!!
