GWILLIAMS
#1 Posted : Friday, October 16, 2009 7:53:28 AM(UTC)
GWILLIAMS
Getting A Fh Code, Checked Water Hoses They Are Straight And And Screens Are Clean, Water Valves Are On Allthe Way On.
sidfink43
#2 Posted : Saturday, October 17, 2009 3:17:42 PM(UTC)
sidfink43
A good possibility is the flowmeter. It is not an expensive part, nor hard to change out, so I would try it and see if that fixes your problem. Here is the part.
Part number: AP4310720
Let us know how it turns out because others have had this problem and the flow meter has fixed it.
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
fh code on whirlpool duet (Washer Repair)
by keithdouglas 3/5/2016 11:56:19 AM(UTC)
Whirlpool Duet GHW9250 FH code (Washer Repair)
by duanec 7/7/2013 6:03:46 PM(UTC)
by Dove 7/14/2012 6:35:16 AM(UTC)
Maytag front loader FH code (Washer Repair)
by tamiwalnut 1/28/2010 1:42:29 PM(UTC)
Fh Code No Or Insufficient Water Supply (Washer Repair)
by meeksj 6/20/2009 9:01:06 PM(UTC)
Kenmore HE3 FH code early in cycle (Washer Repair)
by st_pinetree 2/6/2009 7:10:22 AM(UTC)
fh code (Washer Repair)
by wannnabetech 10/28/2008 10:01:25 AM(UTC)
Duet Washer displays FH code (Washer Repair)
by kaahurley 6/20/2008 7:37:24 AM(UTC)
