Okay so I've been on the forums today trying to figure this out. The drive coupling is good, the clutch assembly / brake cam are good, the water pump isn't clogged and rotates. These seemed to be the most common problems from what I've read here. Anything else I should be checking? I've attached a video of what it sounds like. Whirlpool KAWE760WAL1 wont' spingc - YouTube
Groups: Expert
Run it with cabinet removed and lid switch bypassed. Observe the clutch hub while in spin mode. If clutch hub is not rotating, the gearcase is bad.
Eric
