armrkcin
#1 Posted : Sunday, December 22, 2013 7:02:31 PM(UTC)
armrkcin
Okay so I've been on the forums today trying to figure this out.
The drive coupling is good, the clutch assembly / brake cam are good, the water pump isn't clogged and rotates.
These seemed to be the most common problems from what I've read here.
Anything else I should be checking?
I've attached a video of what it sounds like.
Whirlpool KAWE760WAL1 wont' spingc - YouTube
fairbank56
#2 Posted : Sunday, December 22, 2013 7:31:32 PM(UTC)
fairbank56
Groups: Expert
Run it with cabinet removed and lid switch bypassed. Observe the clutch hub while in spin mode. If clutch hub is not rotating, the gearcase is bad.
Eric
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
Whirlpool Washer Won't Spin, Drain or Agitate (Washer Repair)
by dsagun 8/10/2016 5:19:50 AM(UTC)
Whirlpool washer WON'T spin dry . (Washer Repair)
by zombi71 1/21/2016 9:57:15 AM(UTC)
Whirlpool Washer won't spin/drain (Washer Repair)
by EHankins 9/23/2014 8:08:35 AM(UTC)
Whirlpool washer won't spin but will drain (Washer Repair)
by Mattdb 9/13/2014 7:03:09 AM(UTC)
whirlpool washer won't spin (Washer Repair)
by szoke76 7/26/2014 10:40:09 AM(UTC)
Whirlpool washer won't spin out (Washer Repair)
by fujidave 4/5/2014 3:34:25 PM(UTC)
Whirlpool Washer won't Spin or Agitate (Washer Repair)
by Jimmimech 1/12/2014 6:57:46 PM(UTC)
Whirlpool washer won't spin on spin cycle (Washer Repair)
by u71589 6/2/2013 6:23:26 AM(UTC)
Whirlpool Washer won't spin/agitate. Replaced Direct Drive Motor Coupling. (Washer Repair)
by millmoss 9/10/2012 9:52:02 AM(UTC)
Whirlpool washer won't spin (Washer Repair)
by troycoy12 5/30/2012 1:19:45 AM(UTC)
by chas0073 5/8/2012 10:27:28 AM(UTC)
Whirlpool washer won't spin, drain, or agitate (Washer Repair)
by mosierap 12/14/2011 3:57:37 PM(UTC)
Whirlpool washer won't spin on the gentle knit cycle (Washer Repair)
by Bowdaddy 4/14/2011 8:48:36 AM(UTC)
Whirlpool washer won't spin or agitate (Washer Repair)
by aaronp 4/2/2011 10:21:52 AM(UTC)
