When you push the start button it seems to be running fined. But within seconds it sounds as though the motor is running slow. It is heating the food correctly, and the turntable seems to be running properly. Any suggestions.
The motor might not be able to hold the load. Probably this is the reason why it slows down. You might wanna change the wiring. The Lost Ways
Sometimes it happens due to improper electric supply sometime supply is high and sometime low.I thought you should attach a load-balancer for constant electric flow. visit here for more
