Dryer is shutting off. In order to restart it I have to reset the breaker. Breaker is designated only for dryer. I have replaced these (parts 7,8,9, and 15) part of heating sensors. Dryer worked for almost 2 weeks now starting to shut off again. I dried 4 loads of laundry Saturday night no problem. Sunday night did another 4 loads of laundry. Last load it shut off 20 mins into the cycle. Reset breaker then it worked 5 mins then shut off. This morning I turned the machine back on again reset the breaker and the machine worked the full cycle.
This happened before we replaced the parts then it worked for 2 weeks, now problem is reoccurring. What could be the problem.
Dryer works for a while, have to use breaker to start it up again. What is going wrong?
