Defrost timer is stated as located at freezer control panel. Where is control panel located? At bottom rear of freezer, near outlet plug? Please advise
Here are your parts Parts for Maytag MQF1656TEW02 / - AppliancePartsPros.comTake a look at section 02, it shows the control panel. There is usually a hole in the cover so that you can turn the defrost timer cam without any disassembly. There is not a picture of the cover so I cannot confirm that the above is correct. |
THIS FORUM IS DEAD!!!!!!! |
