Amsel7
#1 Posted : Friday, November 29, 2013 7:26:50 AM(UTC)
Amsel7
Rank:: Member
I need to replace the inner glass on the door of the lower oven.
Is it necessary to remove the door to do this on this particular model?
I have seen instructions for removing the door on other models by inserting removal pins or unlatching retaining clips on the hinges, but this model (late '97/ early '98) has neither of those, and I can't see any other obvious mechanism to get the door off. I'm a little concerned about dismantling the door in place in the open position. Any help would be appreciated. Thanks.
#2 Posted : Saturday, November 30, 2013 3:33:56 AM(UTC)
Yes, the door should be removed from the unit before trying to work on it.
I then lay it on a blanket or towel on a table or counter with the handle over the side of the table so it lays flat.
Here is a link yo the operators manual it has info on removing the door.
http://www.whirlpool.com/digita...0Guide%20-%204451952.pdf
Guest (4)
Kitchenaid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by drill 1/6/2012 5:48:30 AM(UTC)
KitchenAid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by gglbox 3/8/2010 6:18:55 PM(UTC)
oven door glass replacement (Oven Repair (including Ranges and Cooktops))
by Eggman 10/14/2009 1:37:50 PM(UTC)
Oven Door Glass Replacement - Help! (Oven Repair (including Ranges and Cooktops))
by VWC318 11/21/2008 2:04:56 PM(UTC)
Oven Door Glass Replacement Question (Oven Repair (including Ranges and Cooktops))
by ckrobins 2/21/2008 3:19:21 PM(UTC)
Oven door glass replacement (Oven Repair (including Ranges and Cooktops))
by rondelaney 1/20/2008 5:50:19 AM(UTC)
