When installing a new glass in the oven door is there a special treated side of the glass which should be facing in the oven. This is the inside not the outside glass.
Originally Posted by: rondelaney  When installing a new glass in the oven door is there a special treated side of the glass which should be facing in the oven. This is the inside not the outside glass. When installing a new glass in the oven dooris there a special treated side of the glass which should be facing in the oven. This is the inside not the out side glass
How can I tell which is the treated side of this inner window?
