rondelaney
#1 Posted : Sunday, January 20, 2008 5:50:19 AM(UTC)
rondelaney
When installing a new glass in the oven door is there a special treated side of the glass which should be facing in the oven.
This is the inside not the outside glass.
rondelaney
#2 Posted : Sunday, January 20, 2008 5:54:30 AM(UTC)
rondelaney
When installing a new glass in the oven dooris there a special treated side of the glass which should be facing in the oven.
This is the inside not the out side glass
CraigKAnderson
#3 Posted : Friday, August 27, 2010 2:13:56 PM(UTC)
CraigKAnderson
How can I tell which is the treated side of this inner window?
Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by Amsel7 11/29/2013 7:26:50 AM(UTC)
Kitchenaid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by drill 1/6/2012 5:48:30 AM(UTC)
KitchenAid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by gglbox 3/8/2010 6:18:55 PM(UTC)
oven door glass replacement (Oven Repair (including Ranges and Cooktops))
by Eggman 10/14/2009 1:37:50 PM(UTC)
Oven Door Glass Replacement - Help! (Oven Repair (including Ranges and Cooktops))
by VWC318 11/21/2008 2:04:56 PM(UTC)
Oven Door Glass Replacement Question (Oven Repair (including Ranges and Cooktops))
by ckrobins 2/21/2008 3:19:21 PM(UTC)
