Matt18
#1 Posted : Tuesday, November 26, 2013 9:56:49 AM(UTC)
Matt18
The electric dryer was getting too hot and seemed the heater was not turning off. Accessed the tech sheet and ran test#4. I checked the resistance between P4-3 and P4-6 and measured 5-6 Kohms, which told me to replace the control electronics. I ordered a new board and in the meantime, the dryer quit turning on. I replaced the control electronics. Everything comes on but when you hit the start button, I hear a click and the motor does not come on. I ran a diagnostic test but no error codes come up. Advice???
#2 Posted : Thursday, November 28, 2013 1:35:53 AM(UTC)
Parts for Whirlpool WED9400SU0 Dryer - AppliancePartsPros.com
Sounds like the thermal fuse (item 9 in section 03) on the blower.
Check it with your meter.
Since that heater was not turning off I would also check it for grounding.
Unplug the unit and both wires from the heating coil.
Measure across it, should be around 8 to 12 ohms.
Then measure from each side to the case/frame, both should be infinite ohms.
If not the heater is grounded and the control board cannot regulate it's temperature.
Maytag Dryer Not starting (Dryer Repair)
by icetea07 5/31/2017 12:54:26 PM(UTC)
dryer not starting (Dryer Repair)
by DConway0005 3/16/2017 3:40:22 PM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Help! GE dryer not starting (Dryer Repair)
by lelidi 2/4/2015 9:04:46 PM(UTC)
Dryer Not Starting (Dryer Repair)
by dellarte 1/5/2015 5:03:30 AM(UTC)
Maytag Maxima dryer not starting (Dryer Repair)
by ssolle 12/29/2014 8:13:27 PM(UTC)
Dryer not starting (Dryer Repair)
by kbeealexander 6/7/2014 5:59:58 AM(UTC)
by rberger3 10/23/2013 7:34:39 PM(UTC)
Kenmore dryer not starting (Dryer Repair)
by Frustratedinal 5/11/2013 6:18:59 PM(UTC)
Whirlpool Gold gas dryer not starting... (Dryer Repair)
by arvydas512 3/12/2013 10:43:01 AM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Gibson gas dryer not starting (Dryer Repair)
by tad.m 1/31/2013 1:26:02 PM(UTC)
Need help with old Maytag dryer not starting (Dryer Repair)
by momkaren 9/7/2012 6:51:36 PM(UTC)
by Rogscott 4/13/2012 4:34:09 PM(UTC)
