Our oven wont heat up.....blew a circuit and reset it last week and now the oven will not heat up...lights and clock work but no heat. Any ideas?
Does the broil work? If you turn the oven on, do you see an orange glow through the openings in the bottom of the oven?
Yes the broiler works... but there is no orange glow.
Do you have a meter to test for voltage at the bake igniter with?
Yes I do, I will test now for voltage ok
Great! If you have 120 VAC to the igniter, it is bad if it fails to heat up. Let me know what you find.
Originally Posted by: Appliance Ninja Great! If you have 120 VAC to the igniter, it is bad if it fails to heat up. Let me know what you find. Yes reading 120v
