johnmcmillan
#1 Posted : Wednesday, November 20, 2013 6:56:53 AM(UTC)
johnmcmillan
Had a power outage in my area for 3 days. Power is back on, but range is completely dead. Oven, burners, clock, everything. The 240 breaker is on, it's plugged in, and the plug connection is good. Also, none of the wiring looks burned or damaged.
Appliance Ninja
#2 Posted : Wednesday, November 20, 2013 7:02:20 AM(UTC)
Appliance Ninja
This range uses mechanical burner switches, so if they are also dead, it is a power supply issue. Do you have a meter to test voltage with?
#3 Posted : Wednesday, November 20, 2013 7:39:00 AM(UTC)
Try flipping the breaker off/on.
Sometimes you can loose half the line without actually tripping the breaker.
johnmcmillan
#4 Posted : Wednesday, November 20, 2013 8:31:08 AM(UTC)
johnmcmillan
I did that a couple of times.......
johnmcmillan
#5 Posted : Wednesday, November 20, 2013 8:31:53 AM(UTC)
johnmcmillan
No, I do not
Appliance Ninja
#6 Posted : Wednesday, November 20, 2013 8:40:03 AM(UTC)
Appliance Ninja
You will need one to determine what the issue is but I am confident you have an issue with the power supply to the range. You can get a meter at nearly any hardware store for less than $20, in most cases. Once you have one, remove the cover from the cord connections. You will see three terminals. Test between the two outside terminals for 240 VAC. Anything different indicates power supply trouble. Let me know what you find.
johnmcmillan
#7 Posted : Wednesday, November 20, 2013 10:58:24 AM(UTC)
johnmcmillan
Will do.....Thank you very much
Appliance Ninja
#8 Posted : Wednesday, November 20, 2013 12:06:06 PM(UTC)
Appliance Ninja
You are very welcome!
johnmcmillan
#9 Posted : Thursday, November 21, 2013 5:34:10 AM(UTC)
johnmcmillan
It was a power supply issue....problem with the breaker...works fine now...thanks a lot everyone.
Appliance Ninja
#10 Posted : Thursday, November 21, 2013 6:01:08 AM(UTC)
Appliance Ninja
That is great news, glad you got it working, well done! Thank you for taking the time to post back, it is nice to hear the outcome!
