Had a power outage in my area for 3 days. Power is back on, but range is completely dead. Oven, burners, clock, everything. The 240 breaker is on, it's plugged in, and the plug connection is good. Also, none of the wiring looks burned or damaged.
This range uses mechanical burner switches, so if they are also dead, it is a power supply issue. Do you have a meter to test voltage with?
Try flipping the breaker off/on. Sometimes you can loose half the line without actually tripping the breaker. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Try flipping the breaker off/on. Sometimes you can loose half the line without actually tripping the breaker. I did that a couple of times.......
Originally Posted by: Appliance Ninja  This range uses mechanical burner switches, so if they are also dead, it is a power supply issue. Do you have a meter to test voltage with? No, I do not
You will need one to determine what the issue is but I am confident you have an issue with the power supply to the range. You can get a meter at nearly any hardware store for less than $20, in most cases. Once you have one, remove the cover from the cord connections. You will see three terminals. Test between the two outside terminals for 240 VAC. Anything different indicates power supply trouble. Let me know what you find.
Originally Posted by: Appliance Ninja  You will need one to determine what the issue is but I am confident you have an issue with the power supply to the range. You can get a meter at nearly any hardware store for less than $20, in most cases. Once you have one, remove the cover from the cord connections. You will see three terminals. Test between the two outside terminals for 240 VAC. Anything different indicates power supply trouble. Let me know what you find. Will do.....Thank you very much
Originally Posted by: Appliance Ninja  You are very welcome! It was a power supply issue....problem with the breaker...works fine now...thanks a lot everyone.
That is great news, glad you got it working, well done! Thank you for taking the time to post back, it is nice to hear the outcome!
