2 Pages12>
pilot1
#1 Posted : 11 years ago
pilot1
One of the pins from the control board connector (5 wire) is broken off and stuck in the connector. Is there a way to change out the connector or is a whole new wire harness required?
JK
Appliance Ninja
#2 Posted : 11 years ago
Appliance Ninja
Is the broken connector part of the harness or part of the control board? Is the connector labeled on the board, like CON1 or CON2, P2, etc?
pilot1
#3 Posted : 11 years ago
pilot1
The broken pin is from the control panel but broke off in the connector socket. I have a new control panel but need to get the broken pin out of the connector/and or replace wire end in connector.
JK
Appliance Ninja
#4 Posted : 11 years ago
Appliance Ninja
Okay, so you should be able to use a needle nose plier to grab the spade terminal that is stuck in the female connector and simply pull it out.
pilot1
#5 Posted : 11 years ago
pilot1
It is the P 2 connector on the board.
JK
pilot1
#6 Posted : 11 years ago
pilot1
Thanks. I'll try that approach. If the female connector is damaged can it be replaced?
pilot1
#7 Posted : 11 years ago
pilot1
Also, if I were to replace the connector, where can I find a replacement? I don't see the P2 connector listed as a part for this machine.
JK
Appliance Ninja
#8 Posted : 11 years ago
Appliance Ninja
The connector by itself is not available, you would need to replace the harness. Is it one of the small pin connectors or one of the larger 1/4" spade connectors?
pilot1
#9 Posted : 11 years ago
pilot1
It is one of the small pin connectors
Appliance Ninja
#10 Posted : 11 years ago
Appliance Ninja
Okay, if you cannot get the old pin out, the harness will indeed need to be replaced.
2 Pages12>
