One of the pins from the control board connector (5 wire) is broken off and stuck in the connector. Is there a way to change out the connector or is a whole new wire harness required?
JK
Is the broken connector part of the harness or part of the control board? Is the connector labeled on the board, like CON1 or CON2, P2, etc?
The broken pin is from the control panel but broke off in the connector socket. I have a new control panel but need to get the broken pin out of the connector/and or replace wire end in connector.
JK
Okay, so you should be able to use a needle nose plier to grab the spade terminal that is stuck in the female connector and simply pull it out.
It is the P 2 connector on the board.
JK
Thanks. I'll try that approach. If the female connector is damaged can it be replaced?
Originally Posted by: pilot1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks. I'll try that approach. If the female connector is damaged can it be replaced? Also, if I were to replace the connector, where can I find a replacement? I don't see the P2 connector listed as a part for this machine. Thanks JK
The connector by itself is not available, you would need to replace the harness. Is it one of the small pin connectors or one of the larger 1/4" spade connectors?
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The connector by itself is not available, you would need to replace the harness. Is it one of the small pin connectors or one of the larger 1/4" spade connectors? It is one of the small pin connectors
Okay, if you cannot get the old pin out, the harness will indeed need to be replaced.
