The washer is part of the kenmore laundry center.
It fills with water, agitates, until the control dial clicks around to where it should start draining. It then just sits there, silent. If I move the dial around some more, until the second time where it fills, agitates, it does that fine. Once again, when it reaches the second time during the cycle where it should drain, it just stops, and sits.
Any ideas what would cause this?
Groups: Expert
Need the washer model number.
Eric
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Need the washer model number. Eric I believe this is the model: 417.99375100 Thanks
Groups: Expert
That's a Frigidaire model, I'm not familiar with it at all, maybe someone else here can help.
Eric
