I need a little help this morning my GE washer is flashing the four code which is for the shifter moduleI tested the shifter module for continuity I had no continuity which means a circuit is open I understand this I had noone was on it as well I'm guessing because of it being open my question is what part do I need to change to get my washer fixed very mechanically inclined do heating and air for a living. Any help would be appreciated
Groups: Expert
Need the model number of your washer.
Eric
123C8481P001 175D2750G335 Hope these help
Found the right number Model# WPRE6150K1WT Serial#HS122884G
Groups: Expert
