lundie1985
#1 Posted : Thursday, November 14, 2013 3:27:32 PM(UTC)
lundie1985
My washer will not spin I test the shifter for continuity I didn't have anything... n o OHM nothibg what is my problem what part do I need to change the shirfter mode or the motor.is there anything else I could do...also I can't get the left hand threaded nut to break free... please help with this problem. .thanks
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 5:17:44 PM(UTC)
Appliance Ninja
The shifter coil assembly will need to be replaced and is available below.
GE WH38X10017 Shaft & Mode Shifter Asm - AppliancePartsPros.com
The video below will show you how this is done!
How to replace the mode shifter on a GE Hydrowave - YouTube
ge washer flashing code 4 (Washer Repair)
by lundie1985 11/6/2013 4:42:18 AM(UTC)
