lundie1985
#1 Posted : Wednesday, November 6, 2013 4:42:18 AM(UTC)
lundie1985
I need a little help this morning my GE washer is flashing the four code which is for the shifter moduleI tested the shifter module for continuity I had no continuity which means a circuit is open I understand this I had noone was on it as well I'm guessing because of it being open my question is what part do I need to change to get my washer fixed very mechanically inclined do heating and air for a living. Any help would be appreciated
fairbank56
#2 Posted : Wednesday, November 6, 2013 9:36:12 AM(UTC)
fairbank56
Groups: Expert
Need the model number of your washer.
Eric
lundie1985
#3 Posted : Wednesday, November 6, 2013 11:47:00 AM(UTC)
lundie1985
123C8481P001
175D2750G335
Hope these help
lundie1985
#4 Posted : Wednesday, November 6, 2013 1:40:47 PM(UTC)
lundie1985
Found the right number
Model# WPRE6150K1WT
Serial#HS122884G
fairbank56
#5 Posted : Wednesday, November 6, 2013 1:54:38 PM(UTC)
fairbank56
Groups: Expert
Here's the part, mode shifter, that you are asking about.
GE WH38X10017 Shaft & Mode Shifter Asm - AppliancePartsPros.com
ge washer flashing code 4 (Washer Repair)
by lundie1985 11/14/2013 3:27:32 PM(UTC)
