handyman mike
#1 Posted : Tuesday, October 22, 2013 1:17:03 PM(UTC)
handyman mike
I replaced the thermal cut off and the thermostat didn't think to check element same problem looked at element and it was shorted to housing, will this cause my new thermal shutoff and thermostat to fail again?
#2 Posted : Wednesday, October 23, 2013 12:26:18 AM(UTC)
Yes it will probably blow the thermal cut-off again.
It depends how the element shorted.
In some cases the element is controlled by the high limit thermostat instead of the operating thermostat. The high limit's contacts are not designed to open/close often so they will fail. Often they weld together and this then blows the thermal cut-off.
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
Left side heating elements (Oven Repair (including Ranges and Cooktops))
by Guest 11/19/2023 10:24:48 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
A blue wire going to heating element in freezer is blown (Refrigerator & Freezer Repair)
by Guest 6/5/2023 1:14:06 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
Miele (4882) Lower Heating Element (Oven Repair (including Ranges and Cooktops))
by drmoose00 3/22/2023 7:09:47 PM(UTC)
Electrolux range (2008) -heating element won't turn off (Oven Repair (including Ranges and Cooktops))
by xain1z2z 3/19/2023 1:21:18 PM(UTC)
Whirlpool Stove working but both heating elements are not (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 1:06:16 PM(UTC)
Oven wall heating Element broke while cooking (Oven Repair (including Ranges and Cooktops))
by Guest 9/12/2022 1:21:34 PM(UTC)
Dishwasher heating element wont shut off (Dishwasher Repair)
by dperna 2/23/2022 12:20:33 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Heating element will not shut off (Oven Repair (including Ranges and Cooktops))
by Guest 8/13/2021 8:50:42 AM(UTC)
