My dishwasher is leaking water right underneath the overflow float switch, the switch seams to operate ok, but the water is dripping under the dishwasher. Does this mean that I have to replace the overflow float switch? And how, any utube postings out there? Thanks
A model number may help others help you.
I do not know if this unit has the switch as part of the float assembly or if it is a separate part. In any case you may need the float assembly not the switch.
Take the float assembly apart and check/clean it. Often a dirty float assembly will leak. |
THIS FORUM IS DEAD!!!!!!! |
