terry57
#1 Posted : Saturday, October 10, 2009 10:05:20 AM(UTC)
terry57
I have power to the outlet and even to the dryer. It will not turn on. the light does not come on either. what can i do to fix this? thanks
#2 Posted : Sunday, October 11, 2009 3:36:48 AM(UTC)
Here are your parts includes the wiring diagram
Replacement parts for MAYTAG PYE4558AYW | AppliancePartsPros.com
Could be the thermal fuse, Item 5 in the "Heater" section.
Should be 0 ohms at room temperature. Be sure to remove one wire from it when you check it so you do not read an alternate/parallel circuit path.
Note it comes with a new high limit as the high limit should have been regulating the temperature preventing the fuse from blowing.
If the fuse is OK then the door switch would be next.
If the fuse is blown check/clean your vent system.
Also clean the interior including the blower wheel.
Check that the seals in the unit are OK. You are pulling air over the heating element and through the drum so a large air leak will pull in cold air, this will then cause the cycling thermostat which is on the blower to run the dryer hotter than it should.
Might as well also check your rear support rollers, idler roller, front glides and belt for wear and slop. Basically an overhaul.
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Nursing Paper Review SOS: Help a Peer Out! (General Talk)
by Guest 6/19/2024 3:00:02 AM(UTC)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 5/20/2024 7:30:54 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
