kennym
#1 Posted : Thursday, September 5, 2013 11:08:04 AM(UTC)
kennym
washer will fill up timer seems to advance there is a buzz from underneath and then after a few minutes of buzzing it shuts itself off. I have had it apart and motor couplings are good. even had the transmission case apart and everything appears to be ok there. after buzzing for a few minutes the motor does feel warm. I can turn motor coupling and shaft by hand. wondering what to do now?
fairbank56
#2 Posted : Thursday, September 5, 2013 11:22:41 AM(UTC)
fairbank56
Groups: Expert
Motor overload is tripping because motor won't rotate. Remove cabinet and jump out lid switch. Pull pump off back of motor and see if motor runs without it. If so, pump is jammed. If not, in agitation mode with motor humming, spin motor shaft (pump removed) CCW to see if it will start. For spin mode, spin motor shaft CW. Don't leave motor just humming for any length of time, bad for capacitor (which may already be the problem) and motor windings. Possible faults are timer, capacitor, motor switch, motor, faulty wiring connection. If you can't get the motor to start by spinning the motor pump end shaft, remove motor and set on floor and try same thing there, spinning motor shaft when it is just humming to see if it will start.
Eric
Washer quits then starts back after 20mins (Washer Repair)
by dcroom 4/16/2016 11:15:00 AM(UTC)
Kenmore/LG washer quit - won't power on (Washer Repair)
by EddieT 7/25/2015 1:23:17 PM(UTC)
GE Washer quit spinning (Washer Repair)
by cooperk76 6/19/2015 11:58:44 AM(UTC)
Dishwasher quits or won't start (Dishwasher Repair)
by dmac8282 10/16/2014 5:44:25 AM(UTC)
Help! Washer quit mid cycle. (Washer Repair)
by watters32 9/11/2014 1:59:59 PM(UTC)
Kenmore Washer quits (Washer Repair)
by TaraSue79 5/14/2014 3:51:02 PM(UTC)
washer quit (Washer Repair)
by DIY mymy 1/13/2014 1:16:44 PM(UTC)
Washer quit running during final spin cycle, now making horrible noise (Washer Repair)
by justjosh3014 7/31/2012 8:44:25 AM(UTC)
Bosch Dishwasher quit running (Dishwasher Repair)
by jalthof@centurytel.net 6/17/2012 3:40:09 PM(UTC)
washer quit mid cycle (Washer Repair)
by happyearth 5/30/2012 7:54:52 AM(UTC)
Washer quits after it fills with water (Washer Repair)
by nanc450 5/5/2012 11:14:17 AM(UTC)
washer quit clothes locked inside (Washer Repair)
by apache2000 3/31/2012 8:31:21 AM(UTC)
washer quit working (Washer Repair)
by robert rosanna 1/13/2012 7:21:58 AM(UTC)
Washer Quit (Washer Repair)
by rhanne 12/20/2011 12:38:22 PM(UTC)
neptune washer quit during cycle no power (Washer Repair)
by buraggie 11/19/2011 6:06:07 PM(UTC)
