apache2000
#1 Posted : Saturday, March 31, 2012 8:31:21 AM(UTC)
apache2000
washer quit while washing. clothes locked inside. Nothing happens when i push power button, tried holding down on water temp button 4sec on 4sec off for diognostics but nothing. like a fuse blown inside machine. I did check power source, its ok. I am using a shop ligh in the same outlet.:confused:
sidfink43
#2 Posted : Sunday, April 1, 2012 3:43:39 PM(UTC)
sidfink43
If you need to unlock it you can take off the lower service panel and reach up and find a tab on a string. Pull it slowly and it should release the door lock.
It sounds like you main control unit has failed.
