jltuttl
#1 Posted : Friday, August 30, 2013 10:09:52 AM(UTC)
jltuttl
Our dryer has been overheating. It has been running hot. Today it smelled like something electrical was burning. Shortly afterward, it stopped heating altogether. I took the back off and found several burned wires, one of which was burned all the way through. I've attached a picture. What should I look at first?
jltuttl attached the following image(s):
HumboldtRepairMan
#2 Posted : Friday, August 30, 2013 3:18:34 PM(UTC)
HumboldtRepairMan
Inspect harness in those area's it burned your heating element wire is what that is........Ohm test heat element should be 50 ohms or less typically then replaced the thermal cut offs on your element housing and replace the operating thermostat near the blower housing. Cut back any wires that are burnt and buttsplice extension pieces as needed............Check for voltage after you're done and it's up and running the element should have 240v if you have more you have issues.
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
dryer overheating (Dryer Repair)
by dave3712 10/15/2016 8:16:37 AM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
by dadunn60 3/1/2016 9:43:04 AM(UTC)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
Whirlpool Dryer Overheating (Dryer Repair)
by TravisC 1/17/2015 11:13:36 AM(UTC)
by HawtDog 1/12/2015 1:59:21 PM(UTC)
Duet Dryer Overheating (Dryer Repair)
by Snarlybarley 11/20/2013 6:44:40 AM(UTC)
Dryer Overheating When Turned Off (Dryer Repair)
by Jeffshumaker 10/13/2013 4:27:05 PM(UTC)
Dryer overheating and popping safety switch (Dryer Repair)
by sscl14 6/11/2013 8:48:56 PM(UTC)
