Puzzling gas dryer No heat after initial 13 sec burn. Igniter ok. fuse ok. exhaust clear. Now hear is the puzzle with cabinet open drum out, the burner last 13 sec over and over. Put it back together and only 1- 13 sec burn ??????:mad: Help !!!!:)
Sounds exactly like bad coils watch this video..........it also could be a faulty thermostat, ignitor, or even bad venting.....check the air flow going outside and if necessary pull the vent hose off the back and test it not hooked up to the wall.........if your problem goes away you have a clog in the vent and if it doesn't tear it down and start doing continuity tests on the parts inside as the video shows Gas Dryer Repair Video: Heating Problems - YouTube
U tube link was a big help:)
