crhirsh56
#1 Posted : Sunday, August 18, 2013 12:13:22 PM(UTC)
crhirsh56
can brg in outer drum be serviced separately. everything shows brg part of drum.
scott5495
#2 Posted : Sunday, August 18, 2013 1:18:57 PM(UTC)
scott5495
unfortunately, the bearing is part of the tub and cannot be serviced separately. unit must be entirely disassembled to repair. because of cost customers rarely repair. sorry
#3 Posted : Monday, August 19, 2013 6:19:23 AM(UTC)
Parts for Maytag MAH7500AWW Washer - AppliancePartsPros.com
Go to section 08 and then click on the outer drum (item 1) and read the Q&A.
Here is also some additional info.
http://forum.appliancepartspros...t=bearing+replace+maytag
Note that I am not 100% sure of this but you may want to do some additional investigation.
scott5495
#4 Posted : Monday, August 19, 2013 8:30:07 AM(UTC)
scott5495
have worked on maytag 32 years. trust me. you have to replace outer tub.
I guess to be a senior expert you have to own part of the business.
crhirsh56
#5 Posted : Monday, August 19, 2013 4:59:51 PM(UTC)
crhirsh56
thanks for the info.
Adam / APP Team
#6 Posted : Thursday, August 22, 2013 6:30:23 AM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Scott both you and Denman are correct. Yea Maytag/Whirpool say's replace the entire tub, always have and I'm sure they always will. Trust me, I worked for them for many yrs. also, started on their Tech Line when it was MAYCOR and ended up as a District Service Manager. Then came a thing called Whrilpool. I lived through the Neptune fiasco. Prior to that I had my own Service Company and grew up in the Appliance Service business in my fathers company. I'm no youngster either.
Maytag never gave out the bearing part numbers or put them on their parts page, and I'm sure they never will. But there is a part # for them, and has been for yrs. Personally I wouldn't take on the job of doing the bearings separately, especially for a older Neptune with their track record. Obviously it's a complete teardown and removing them and reinstalling the bearings correctly requires great care.
I don't want to get in the middle of two differing opinions, but I'd thought I'd shed some light on this.
crhirsh56
#7 Posted : Thursday, August 22, 2013 11:08:35 AM(UTC)
crhirsh56
i understand your concern. i work on ag equipment and standby gensets. not sure how brg is secured in housing. the worst that can happen is damaging the brg bore.thanks for your input
scott5495
#8 Posted : Thursday, August 22, 2013 4:55:37 PM(UTC)
scott5495
yes it can be done. I have done -----one------, because I will never do another. I did that one for inlaws. by the time you do the tear down, beat the bearing out, replace and replace the seals and reassemble, believe me, you will never want to see another one. I am with adam, not worth the hassle, so I always discourage it by saying you have to replace the rear tub.
#9 Posted : Friday, August 23, 2013 4:32:34 AM(UTC)
Just Google "tony tool neptune"
Also search on You Tube for "neptune bearing"
Then you can decide if it is worth the hassle.
scott5495
#10 Posted : Friday, August 23, 2013 6:42:18 AM(UTC)
scott5495
checked out video. man that is easy! I did two in the last ten minutes.!
rock on, Denman is the man!
I found another site to help people on appliance repair. they don't even sell parts. I started thinking, "why am I helping these guys sell parts?"
just trying to help. but no good deed goes unpunished. adios!
