sarabelle
#1 Posted : Sunday, August 4, 2013 1:54:13 PM(UTC)
sarabelle
Hi all, just bought a house with a Frigidaire pure-source fridge/freezer (model frs26lh5ds1). It wasn't hooked up to water supply when I moved in, so when I did finally get around to it, I found the water inlet valve was busted. I repaired that (myself) and have no water leaking from the bottom of the refrigerator. My problem is now that the water leaks from the ice/water filter (that I also just replaced because it is unknown the last time it was done) inside the fridge.
Where do I go from here? I am not paying someone another $75 to tell me they can fix a water inlet valve for $225, when I did it myself for $60.
Sincerely,
first time homeowner with limited skills ;) Sara,
#2 Posted : Wednesday, August 7, 2013 2:20:32 AM(UTC)
Parts for Frigidaire FRS26LH5DS1 Refrigerator - AppliancePartsPros.com
Here is the operators manual, in case you do not have it.
http://manuals.frigidaire.com/p...Anderson/240581300en.pdf
Take a look at the Control Parts section in the above parts.
Note that all parts for the filter assembly are not shown in the parts breakdown but are listed so also look at the listing. Depending where your leak is you may just need a new O-ring. Clicking on a parts picture or description will bring up more info.
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
Samsung french door bottom freezer loud buzzing and water leak (Refrigerator & Freezer Repair)
by surgeslayer2 10/19/2023 3:33:56 AM(UTC)
Speed Queen washer water leak (Washer Repair)
by Guest 5/20/2023 4:29:11 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Whirlpool fridge water leak not solvable with ptrap (Refrigerator & Freezer Repair)
by richdell 5/2/2021 5:33:45 AM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 4/13/2019 9:06:58 AM(UTC)
