When Not In Use Oven Will Beep Then E6 F2 Codes Appear Then At Times It Goes Blank. I Can Turn The Light On From The Control Panes When This Happens But Nothing Else Works. This Oven Is 11 Years Old This Year. Help!
1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 sec., replace keypad.
If the display is blank, you don't need the control panel, you need the control board. The error code is misleading. Usually the display is blank, but the oven light works if you open the door.
