res55
#1 Posted : Monday, August 27, 2012 1:12:36 PM(UTC)
res55
I have a Whirlpool Gold AccuBake double oven model # GRD307PRS01 which is about 5 years old. The control panel has gone completly blank. The only key which functions is the light. Some others will beep but not operate. When I press the Start button I get two quick beeps followed by three more (not sure that means anything). I power cycled the unit by shutting off the circuit but this had no impact on the problem.
Any suggestions?
Simon / APP Team
#2 Posted : Monday, August 27, 2012 1:35:54 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the correct model number of the oven. This one doesn't come up.
Simon.
res55
#3 Posted : Monday, August 27, 2012 2:01:47 PM(UTC)
res55
Sorry the correct model # is GBD307PRS01
Simon / APP Team
#4 Posted : Monday, August 27, 2012 2:50:24 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Using the multimeter check for 120VAC to the control board between Bk and W.
If voltage present - disconnect the flex ribbon connector from the control board and clean the edge with isopropyl
alcohol.
If that doesn't help - replace the touch control
Part number: W10161676
for black
for silver Part number: W10112118
Thank you. Post the results.
Simon.
