I have a Whirlpool Gold AccuBake double oven model # GRD307PRS01 which is about 5 years old. The control panel has gone completly blank. The only key which functions is the light. Some others will beep but not operate. When I press the Start button I get two quick beeps followed by three more (not sure that means anything). I power cycled the unit by shutting off the circuit but this had no impact on the problem.
Any suggestions?
Groups: APP Team
Hi.
Please provide the correct model number of the oven. This one doesn't come up.
Simon.
Sorry the correct model # is GBD307PRS01
Groups: APP Team
Hi. Using the multimeter check for 120VAC to the control board between Bk and W. If voltage present - disconnect the flex ribbon connector from the control board and clean the edge with isopropyl alcohol. If that doesn't help - replace the touch control Part number: W10161676
