Roy Francis
#1 Posted : Monday, July 29, 2013 3:00:19 PM(UTC)
Roy Francis
When Not In Use Oven Will Beep Then E6 F2 Codes Appear Then At Times It Goes Blank. I Can Turn The Light On From The Control Panes When This Happens But Nothing Else Works. This Oven Is 11 Years Old This Year. Help!
HumboldtRepairMan
#2 Posted : Monday, July 29, 2013 3:43:21 PM(UTC)
HumboldtRepairMan
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
If the display is blank, you don't need the control panel, you need the control board. The error code is misleading. Usually the display is blank, but the oven light works if you open the door.
Whirlpool gold double oven display out (Oven Repair (including Ranges and Cooktops))
by dman0006 12/20/2016 5:25:28 AM(UTC)
Whirlpool gold double oven (Oven Repair (including Ranges and Cooktops))
by Cruth 3/16/2014 10:43:52 AM(UTC)
Whirlpool Gold Double Oven (Oven Repair (including Ranges and Cooktops))
by grifmart 11/30/2012 12:35:02 PM(UTC)
Control Panel Whirlpool Gold Double Oven (Oven Repair (including Ranges and Cooktops))
by res55 8/27/2012 1:12:36 PM(UTC)
Whirlpool Gold Double Oven Display Out (Oven Repair (including Ranges and Cooktops))
by fireresource 4/6/2009 6:32:55 PM(UTC)
