I have 2 Commercial Whirlpool Washers and I am having the same problem with both of them ... the rinse cycle only fills about 1/4 water ... is there a switch that controls the amount of water disbursed? Or is the control panel bad? The owner is cheap and I was wondering if they could control the amount of water used?
Groups: Expert
This is normal operation due to government mandated water and energy restrictions. It can be bypassed for use outside of the U.S. There is a "feature connector" behind the control panel. Unplug the violet/yellow wire connection and plug in the feature connector. Now the rinse level will be the same as wash level.
Eric
thank you very much ... :-)
is the "feature connector" in the box above the coin box?
Groups: Expert
Should be behind the control panel. Trace wires between the two pressure switches and water level switch to locate it.
Eric
thanks again ... Margie :-)
I have the same model but ending in TQ2. My tenant swears it's not right. She has been using it for 5 years. I ran it on the rinse. It's more like half full. Does this seem right?? g20zoom attached the following image(s):
Just in case. I think I see the purple yellow wire on the left of the brown board What wire do I connect in it place if out if the US? What does the feature wire look like? Thanks! g20zoom attached the following image(s):
