justmargie1
#1 Posted : Monday, July 29, 2013 8:33:43 AM(UTC)
justmargie1
I have 2 Commercial Whirlpool Washers and I am having the same problem with both of them ... the rinse cycle only fills about 1/4 water ... is there a switch that controls the amount of water disbursed? Or is the control panel bad? The owner is cheap and I was wondering if they could control the amount of water used?
fairbank56
#2 Posted : Monday, July 29, 2013 9:10:03 AM(UTC)
fairbank56
Groups: Expert
This is normal operation due to government mandated water and energy restrictions. It can be bypassed for use outside of the U.S. There is a "feature connector" behind the control panel. Unplug the violet/yellow wire connection and plug in the feature connector. Now the rinse level will be the same as wash level.
Eric
justmargie1
#3 Posted : Monday, July 29, 2013 9:40:11 AM(UTC)
justmargie1
thank you very much ... :-)
justmargie1
#4 Posted : Tuesday, July 30, 2013 1:41:46 PM(UTC)
justmargie1
is the "feature connector" in the box above the coin box?
fairbank56
#5 Posted : Tuesday, July 30, 2013 4:02:49 PM(UTC)
fairbank56
Groups: Expert
Should be behind the control panel. Trace wires between the two pressure switches and water level switch to locate it.
Eric
justmargie1
#6 Posted : Tuesday, July 30, 2013 8:57:14 PM(UTC)
justmargie1
thanks again ... Margie :-)
g20zoom
#7 Posted : Friday, August 19, 2016 10:24:13 AM(UTC)
g20zoom
I have the same model but ending in TQ2. My tenant swears it's not right. She has been using it for 5 years.
I ran it on the rinse. It's more like half full.
Does this seem right??
g20zoom attached the following image(s):
g20zoom
#8 Posted : Friday, August 19, 2016 11:18:08 AM(UTC)
g20zoom
Just in case. I think I see the purple yellow wire on the left of the brown board
What wire do I connect in it place if out if the US?
What does the feature wire look like?
Thanks!
