daveb1222
#1 Posted : Sunday, July 28, 2013 3:08:16 PM(UTC)
daveb1222
Kenmore dishwasher will not turn on heated dry light lights as well as normal wash but start button does not accept command unit will not start. lights go out after prox. 30sec
HumboldtRepairMan
#2 Posted : Sunday, July 28, 2013 3:18:45 PM(UTC)
HumboldtRepairMan
sounds like your touchpad is going out or the main board.......turn off breaker disconnect the ribbon of the touchpad at the main board and go turn the breaker back on you should hear the drain pump trying to drain within a couple minutes....if it doesn't then you have a bad main board most likely and if it does you have a bad touchpad....sometimes you have to replace both.....
kenmore dishwasher 66513043K116 still not draining, after changing drain motor? (Dishwasher Repair)
by thivakaran 12/5/2022 11:47:06 AM(UTC)
Repeating Error 24 on Kenmore Dishwasher (Dishwasher Repair)
by abidh2 12/24/2021 4:45:12 PM(UTC)
Kenmore Dishwasher 665.13733K600 Major Leak Problem (Dishwasher Repair)
by Ken More73 11/10/2021 12:22:29 PM(UTC)
Kenmore Dishwasher - no control lights but washer works (Dishwasher Repair)
by toibn46 10/22/2021 10:08:47 AM(UTC)
Kenmore Dishwasher Keeps Running (Dishwasher Repair)
by VicRattlehead 9/21/2021 1:25:13 PM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Kenmore dishwasher turning on by itself (Dishwasher Repair)
by Guest 5/24/2021 11:06:12 AM(UTC)
Kenmore Dishwasher drain output has stong sulphur smell (Dishwasher Repair)
by Larbo 1/13/2021 3:35:42 PM(UTC)
Kenmore Dishwasher Heater (Dishwasher Repair)
by mikedbom 11/11/2020 4:21:33 PM(UTC)
Kenmore Dishwasher Smartwash (Dishwasher Repair)
by katzman299 1/4/2020 11:02:06 AM(UTC)
Kenmore dishwasher model 665.15113K211 started high pitch sound between cycles (Dishwasher Repair)
by redeyedog 5/10/2019 8:21:48 AM(UTC)
Kenmore Dishwasher control pannel not working (Dishwasher Repair)
by Douglas Scherer 3/14/2019 6:32:33 PM(UTC)
Kenmore Dishwasher fills then drains (Dishwasher Repair)
by qkantaris 1/5/2019 8:39:01 PM(UTC)
How do you install Part W11048936 for a Kenmore Dishwasher (Dishwasher Repair)
by S Hall 3/23/2018 4:46:54 PM(UTC)
Can't loosen impeller part for kenmore dishwasher (Dishwasher Repair)
by rbhall52 9/5/2017 12:04:52 PM(UTC)
