Kenmore dishwasher will not turn on heated dry light lights as well as normal wash but start button does not accept command unit will not start. lights go out after prox. 30sec
sounds like your touchpad is going out or the main board.......turn off breaker disconnect the ribbon of the touchpad at the main board and go turn the breaker back on you should hear the drain pump trying to drain within a couple minutes....if it doesn't then you have a bad main board most likely and if it does you have a bad touchpad....sometimes you have to replace both.....
