rva-fixit
#1 Posted : Sunday, July 28, 2013 6:59:31 AM(UTC)
rva-fixit
no manual and need wiring diagram, specifically connections to heating element that I am replacing.
#2 Posted : Monday, July 29, 2013 2:34:09 AM(UTC)
I cannot find a wiring diagram for this unit.
On most units the heater is hooked up as follows.
One side goes to the motor's centrifugal switch (often a red wire).
The other side goes to high limit thermostat, then the operating thermostat , then the thermal cut-off, then a set of contacts in the timer.
Need wiring diagram for Duet GHW9150PW1 (Washer Repair)
by Conesus 12/14/2022 10:50:49 AM(UTC)
Need wiring diagram for heating element/thermal fuse/hi-temp fuse forAmana ALE643RAW. (Dryer Repair)
by mdjetdoc 1/13/2016 11:31:57 AM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
need wiring diagram (Oven Repair (including Ranges and Cooktops))
by fudge2009 4/26/2014 3:49:14 AM(UTC)
by tylerlee 8/10/2013 5:19:23 PM(UTC)
Need wiring diagram for this refer (Refrigerator & Freezer Repair)
by nan1112 7/26/2013 3:47:47 AM(UTC)
Need wiring diagram (Oven Repair (including Ranges and Cooktops))
by Charliez 12/17/2012 3:26:15 PM(UTC)
Need wiring diagram for GE dryer (Dryer Repair)
by rick88ss 10/22/2012 7:55:10 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
Need wiring diagram (Dryer Repair)
by Rick41 5/1/2012 8:06:34 AM(UTC)
wiring disconnected from timer, need wiring diagram (Dryer Repair)
by Chip65 12/2/2011 2:51:45 PM(UTC)
Need wiring diagram for Kenmore 400 series dryer (Dryer Repair)
by MarthaV 7/15/2011 8:03:59 AM(UTC)
need wiring diagram for fridge (Refrigerator & Freezer Repair)
by misterfixall 5/5/2011 4:55:11 AM(UTC)
Need wiring diagram. Help. (Refrigerator & Freezer Repair)
by justin99 2/25/2011 9:13:19 AM(UTC)
Need wiring diagram (Heating, Ventilation, and Air Conditioning (HVAC))
by MagicMan 5/27/2010 6:23:27 AM(UTC)
