Never had a problem with dishwasher until now. Will not start. Has power. Worked fine the day before.
The first thing (assuming there is 120V at the power outlet and the plug is not loose) I would do is remove the bottom panel, open the terminal box (unplug the power cord first) and check for burned wires. If there is nothing wrong, remove the inner door panel and the cover and check the door switches for continuity. Inspect all wires. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter -How to check coninuity with Ohmmeter- The part number for the door switch assembly is AP403996 Here are the break down diagrams for the Maytag dishwasher Model DWC7400AAWGene.
