mikegm
#1 Posted : Tuesday, February 5, 2008 12:51:21 PM(UTC)
mikegm
Never had a problem with dishwasher until now. Will not start. Has power. Worked fine the day before.
#2 Posted : Wednesday, February 6, 2008 11:25:53 AM(UTC)
The first thing (assuming there is 120V at the power outlet and the plug is not loose) I would do is remove the bottom panel, open the terminal box (unplug the power cord first) and check for burned wires.
If there is nothing wrong, remove the inner door panel and the cover and check the door switches for continuity. Inspect all wires.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter -How to check coninuity with Ohmmeter
- The part number for the door switch assembly is AP403996
Here are the break down diagrams for the Maytag dishwasher Model DWC7400AAW
Whirlpool dishwasher will not run (GU1500XTLS2) (Dishwasher Repair)
by mindnmines 3/3/2017 4:47:18 AM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
by gerry d 7/26/2014 2:22:59 PM(UTC)
Roper dishwasher will not run cycles (Dishwasher Repair)
by Lfrisk 12/3/2013 10:53:29 AM(UTC)
GE dishwasher will not run (Dishwasher Repair)
by carlos_m 10/14/2012 3:34:11 PM(UTC)
Dishwasher will not run (Dishwasher Repair)
by SteveO59 12/4/2011 5:06:50 AM(UTC)
dishwasher will not run no sign of life (Dishwasher Repair)
by peter pirri 12/9/2010 12:20:07 PM(UTC)
by mdr6140 11/21/2010 2:00:28 AM(UTC)
by tapcon 4/7/2010 3:41:55 PM(UTC)
by DeaconJ 11/29/2009 2:19:15 PM(UTC)
by schmidt17 8/4/2009 9:32:39 AM(UTC)
by superior l & l 7/18/2009 10:30:55 AM(UTC)
Dishwasher will not run through cycles (Washer Repair)
by Butters 11/12/2008 5:53:11 PM(UTC)
by mudhen 6/16/2008 7:49:51 PM(UTC)
