nporter118
#1 Posted : Thursday, July 11, 2013 9:12:45 AM(UTC)
nporter118
My Stove burners and broiler comes on with no problem. But when I turn on the oven it only gets warm and never reaches the desired temperature. The control buttons for stove work fine as well everything lights up as it suppose to.
scott5495
#2 Posted : Thursday, July 11, 2013 2:01:28 PM(UTC)
scott5495
it is most likely a bad bake element. when you turn the over on bake, the broil element comes on either on half power or cycles intermittently. that is where you are getting your heat in the oven. it will heat but not likely to reach temp. check bake element for burn marks, or if you have a meter check the element for continuity. set meter on lowest scale, you should read about 15 to 30 ohms.
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
oven won't heat, replaced element seems to have caused more problems (Oven Repair (including Ranges and Cooktops))
by kepu 1/8/2019 10:48:17 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
Gas Oven won't heat but broiler and burners work fine (Oven Repair (including Ranges and Cooktops))
by Melissabrooks 3/4/2018 6:42:44 AM(UTC)
Oven won't heat (Oven Repair (including Ranges and Cooktops))
by mbreihan59 2/5/2018 5:48:30 PM(UTC)
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 11/7/2016 5:26:07 PM(UTC)
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 11/24/2015 7:23:04 AM(UTC)
GE Profile Convection Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by igotboost 8/7/2015 10:38:00 AM(UTC)
Ikea Nutid Wall Oven won't heat (Oven Repair (including Ranges and Cooktops))
by Triciav48 6/29/2015 6:36:33 AM(UTC)
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 6/28/2015 4:52:44 PM(UTC)
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 3/15/2015 10:45:08 AM(UTC)
by trisha57 4/28/2014 10:23:33 AM(UTC)
Top oven won't heat after self cleaning was done (Oven Repair (including Ranges and Cooktops))
by Dede B 4/6/2014 2:22:53 PM(UTC)
by JLH69 4/5/2014 1:10:19 PM(UTC)
