xtrmn8r
#1 Posted : Tuesday, July 2, 2013 10:38:21 AM(UTC)
xtrmn8r
Bottom element only worked part time. Broil element works fine. Replace bottom element. No change. If it is in the control panel, do i need the whole panel or just the component behind the panel. Any help appreciated..Model # correction...PLEB30S9FCA
#2 Posted : Thursday, July 4, 2013 5:17:17 AM(UTC)
[COLOR="Blue"]Bottom element only worked part time.[/COLOR]
Not sure what you mean.
An element will not be on all the time as it is controlled by the oven sensor temperature. Also most units will switch back and forth between the bake and broil elements when in preheat and bake modes. This provides a more even temperature gradient in the oven.
What if any other symptoms do you have?
xtrmn8r
#3 Posted : Friday, July 5, 2013 5:29:17 AM(UTC)
xtrmn8r
Sorry. Should have been more clear. Bottom element stopped working but broil element would still work even during pre-heat however oven would not get to temperature setting. Changed bottom element and the element still does not get hot. When I changed the element it heated up momentarily the first time i used it. After that nothing.
#4 Posted : Friday, July 5, 2013 7:22:55 AM(UTC)
Parts for Frigidaire PLEB30S9FCA Wall Oven - AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/p...assomption/318046235.pdf
First I would remove power from the unit and pull the bake element.
Then check it with a meter,
Just in case it blew as soon as power was applied to it.
If OK then check that the wires to the element are OK.
Check that the connections and soldering on the control board to the bake element are OK.
If they are OK then odds are high that the control board is toast.
Since it stays in preheat the board is getting the correct temperature reading from the oven sensor but for some reason is not turning on the bake element.
xtrmn8r
#5 Posted : Monday, July 8, 2013 7:10:33 AM(UTC)
xtrmn8r
Thanks for the help. So do I need the control panel (AP3950999) or just the Clock/timer (3781481)
#6 Posted : Monday, July 8, 2013 1:24:11 PM(UTC)
You should only need the clock/timer
Part number: AP3781481
xtrmn8r
#7 Posted : Tuesday, July 9, 2013 5:09:24 AM(UTC)
xtrmn8r
Control panel has no error but status shows sensing mode light ON (Dryer Repair)
by Neil74 4/28/2024 6:56:25 AM(UTC)
Subzero 650 Control Panel (Refrigerator & Freezer Repair)
by kbf99 2/14/2024 5:06:04 AM(UTC)
Control panel goes dark and loud clicking noise (Refrigerator & Freezer Repair)
by Guest 2/6/2024 12:57:10 PM(UTC)
Control panel for GE Spectra Stove Model # JBP79WB4WW (Appliance Parts)
by janieben@rainbowtel.net 1/22/2024 5:16:12 PM(UTC)
LG LFXS28968S /00 control panel removal (Refrigerator & Freezer Repair)
by Guest 11/15/2023 5:36:56 PM(UTC)
Whirlpool Control Panel VOM Testing (Washer Repair)
by Guest 10/19/2023 10:23:21 AM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
LG control panel issue (Dishwasher Repair)
by Guest 9/10/2023 7:18:58 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Dispenser control panel is dead (Refrigerator & Freezer Repair)
by Expat 1/21/2023 1:56:42 PM(UTC)
Kitchenaid Control panel melted (Dishwasher Repair)
by Guest 12/9/2022 2:41:47 PM(UTC)
Whirlpool WRF555SDHV refrigerator dispenser control panel (Refrigerator & Freezer Repair)
by janinePR 12/8/2022 2:17:23 PM(UTC)
GE GSS25WGTGBB - Control panel dies when turning on dispenser light (Refrigerator & Freezer Repair)
by noparts 9/19/2022 6:17:40 AM(UTC)
Maytag MHWE300VW00 Control Panel shuts off, then on, then off... (Washer Repair)
by ab2112 8/1/2022 10:00:14 AM(UTC)
