Water collects under the evaporator fan and freezes. I use a hair dryer to thaw the water and remove the water manually. This works for a couple of days and the whole process repeats itself. What am I looking for? Thanks.
Most likely the problem is a clogged drain hose (#148 on the diagram) Gene.
