Went to use microwave then heard a loud pop noise. Stopped microwave did not smell anything or see any physical damage so i retried microwave. It was louder than usual but everything seemed to work. I removed item i was trying to heatup and it was still cold. Tried again and found out microwave will not heat but everything else works. Unit is 7 years old. The manual has 4 models on it CGLMV169----GLMV169/ CPLMV169---PLMV169. Any help with this matter would be greatly appreciated. Thanks.
I Think The Heating Sensors Of Your Microwave Is Gone Out Of Life. So Its Better To Check Them And Change If You Find Them In Unworking Condition. click here >>> REI Coupon Code
Originally Posted by: RichardMark  I Think The Heating Sensors Of Your Microwave Is Gone Out Of Life. So Its Better To Check Them And Change If You Find Them In Unworking Condition okay. What would cause the loud pop when it stopped working?
