rmitche2@stx.rr.com
#1 Posted : Monday, February 4, 2008 7:50:49 AM(UTC)
rmitche2@stx.rr.com
Rank:: Member
Oven does not bake properly. Broiler heats to "red" on broil, seems not to get "hot" enough on bake. Bottom unit heats to "red".
#2 Posted : Monday, February 4, 2008 3:43:00 PM(UTC)
The broil heating element should be "red" hot only when the Broil mode used.
Put the oven thermometer in the middle of the oven and measure the temperature inside the oven while the temperature is set for 350°F.
Post the results.
Also the model number you posted is incorrect. Verify and repost it, please.
robert mikolay (Refrigerator & Freezer Repair)
by Robert Mikolay 10/31/2016 10:31:50 AM(UTC)
Robert (Refrigerator & Freezer Repair)
by rawhitman1@aol.com 2/12/2013 4:15:26 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
Robert (Washer Repair)
by DALRO 5/1/2012 2:33:49 PM(UTC)
robert (Refrigerator & Freezer Repair)
by RobertR70 4/6/2012 4:40:10 PM(UTC)
Robert R. (Washer Repair)
by Robert R. 5/14/2011 3:47:52 PM(UTC)
robertshaw defective gas valve? (Heating, Ventilation, and Air Conditioning (HVAC))
by lrg47 1/31/2010 10:10:08 AM(UTC)
Robertshaw gas valve (Heating, Ventilation, and Air Conditioning (HVAC))
by feded 10/12/2009 8:56:43 PM(UTC)
OLD Modern Maid Robert Shaw Oven (Oven Repair (including Ranges and Cooktops))
by Hodgi 9/23/2009 2:35:58 PM(UTC)
10 yr old robert shaw gas valve installing new one (General Talk)
by jess.good@live.com 12/9/2008 3:26:59 PM(UTC)
Robertshaw gas valve question (bad regulator?) (Heating, Ventilation, and Air Conditioning (HVAC))
by Fong 6/10/2008 7:25:20 AM(UTC)
Old Robert Shaw thermostat connections (Oven Repair (including Ranges and Cooktops))
by jkosanke 5/1/2008 8:19:16 AM(UTC)
