DALRO
#1 Posted : Tuesday, May 1, 2012 2:33:49 PM(UTC)
DALRO
Door strike is broken and broken part is in door do we need to remove broken piece before replacing the strike
Simon,
Broken part is in the door latch (upper hole)
Simon / APP Team
#2 Posted : Tuesday, May 1, 2012 3:34:47 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sorry. Do you mean the broken off piece is inside the door latch not inside the door?
Simon.
DALRO
#3 Posted : Wednesday, May 2, 2012 5:27:41 AM(UTC)
DALRO
Simon,
Broken part is in the door latch (upper hole) I can see the broken part but it is hard to remove do you have a suggestion
Simon / APP Team
#4 Posted : Wednesday, May 2, 2012 8:43:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
In your case I recommend to replace the door latch also.I know it's much more $ but the chance that you will damage it trying to remove the broken piece is very grate.
The door latch Part number: 131763202
The strike Part number: 134456600
Here are the breakdown diagrams and Replacement parts for Frigidaire ATF6000FS1 WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Robert Shaw Fireplace Gas Valve - Sticks (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 11/15/2023 4:04:14 PM(UTC)
can I replace my DCS igniter (211541) with Robert Shaw replacement? (Oven Repair (including Ranges and Cooktops))
by joeb2 2/24/2019 4:16:29 AM(UTC)
robert mikolay (Refrigerator & Freezer Repair)
by Robert Mikolay 10/31/2016 10:31:50 AM(UTC)
Robert (Refrigerator & Freezer Repair)
by rawhitman1@aol.com 2/12/2013 4:15:26 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
robert (Refrigerator & Freezer Repair)
by RobertR70 4/6/2012 4:40:10 PM(UTC)
Robert R. (Washer Repair)
by Robert R. 5/14/2011 3:47:52 PM(UTC)
robertshaw defective gas valve? (Heating, Ventilation, and Air Conditioning (HVAC))
Belarus lrg47 1/31/2010 10:10:08 AM(UTC)
Robertshaw gas valve (Heating, Ventilation, and Air Conditioning (HVAC))
by feded 10/12/2009 8:56:43 PM(UTC)
OLD Modern Maid Robert Shaw Oven (Oven Repair (including Ranges and Cooktops))
by Hodgi 9/23/2009 2:35:58 PM(UTC)
10 yr old robert shaw gas valve installing new one (General Talk)
by jess.good@live.com 12/9/2008 3:26:59 PM(UTC)
Robertshaw gas valve question (bad regulator?) (Heating, Ventilation, and Air Conditioning (HVAC))
by Fong 6/10/2008 7:25:20 AM(UTC)
Old Robert Shaw thermostat connections (Oven Repair (including Ranges and Cooktops))
by jkosanke 5/1/2008 8:19:16 AM(UTC)
robert (Oven Repair (including Ranges and Cooktops))
by rmitche2@stx.rr.com 2/4/2008 7:50:49 AM(UTC)
