Door strike is broken and broken part is in door do we need to remove broken piece before replacing the strike
Simon, Broken part is in the door latch (upper hole)
Groups: APP Team
Originally Posted by: DALRO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Door strike is broken and broken part is in door Hi. Sorry. Do you mean the broken off piece is inside the door latch not inside the door? Simon.
Originally Posted by: DALRO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Door strike is broken and broken part is in door do we need to remove broken piece before replacing the strike
Simon, Broken part is in the door latch (upper hole) I can see the broken part but it is hard to remove do you have a suggestion
Groups: APP Team
Hi. In your case I recommend to replace the door latch also.I know it's much more $ but the chance that you will damage it trying to remove the broken piece is very grate. The door latch Part number: 131763202
Robert Shaw Fireplace Gas Valve - Sticks
(Heating, Ventilation, and Air Conditioning (HVAC))
by Guest
11/15/2023 4:04:14 PM(UTC)
can I replace my DCS igniter (211541) with Robert Shaw replacement?
(Oven Repair (including Ranges and Cooktops))
by joeb2
2/24/2019 4:16:29 AM(UTC)
robert mikolay
(Refrigerator & Freezer Repair)
by Robert Mikolay
10/31/2016 10:31:50 AM(UTC)
Robert
by rawhitman1@aol.com
2/12/2013 4:15:26 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and
by bigdaddy88
8/2/2012 4:16:30 PM(UTC)
robert
by RobertR70
4/6/2012 4:40:10 PM(UTC)
Robert R.
(Washer Repair)
by Robert R.
5/14/2011 3:47:52 PM(UTC)
robertshaw defective gas valve?
by lrg47
1/31/2010 10:10:08 AM(UTC)
Robertshaw gas valve
by feded
10/12/2009 8:56:43 PM(UTC)
OLD Modern Maid Robert Shaw Oven
by Hodgi
9/23/2009 2:35:58 PM(UTC)
10 yr old robert shaw gas valve installing new one
(General Talk)
by jess.good@live.com
12/9/2008 3:26:59 PM(UTC)
Robertshaw gas valve question (bad regulator?)
by Fong
6/10/2008 7:25:20 AM(UTC)
Old Robert Shaw thermostat connections
by jkosanke
5/1/2008 8:19:16 AM(UTC)
robert
by rmitche2@stx.rr.com
2/4/2008 7:50:49 AM(UTC)
