Chrisbot
#1 Posted : Thursday, May 16, 2013 4:34:39 PM(UTC)
Chrisbot
I have a Kenmore Elite Smartheat Quitepak9 gas dryer. It will only work if I keep switching from pushing the start button to pause button and so on. Eventually it will start but only runs for a bit then I have to repeat the whole process. I order a thermal fuse but did not work. PLEASE HELP
Simon / APP Team
#2 Posted : Thursday, May 16, 2013 7:37:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Please, provide the complete model number of the dryer.
Simon.
Chrisbot
#3 Posted : Friday, May 17, 2013 4:29:15 PM(UTC)
Chrisbot
The Model number is 110.95862401
The Serial number is MS2201031
Chrisbot
#4 Posted : Saturday, May 18, 2013 2:22:22 PM(UTC)
Chrisbot
ran diagnostics no errors. Ran test for moisture sensor and it failed. Took apart the sensors and cleaned them up and now it passes. Any other ideas anybody. Thermistor test passed as well.
Simon / APP Team
#5 Posted : Monday, May 20, 2013 9:35:46 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Most likely the problem is with main control board
Part number: 8546219
Remove it and check the solderind at the back. Possibly one of the relay's contacts needs a drop of solder.
If not then try to replace the control board.
Post ther results.
Simon.
P.S. You can return the part if it's not going to fix the problem.
Chrisbot
#6 Posted : Tuesday, May 21, 2013 3:41:12 PM(UTC)
Chrisbot
Ok I will take a look at the board thank you for the advice.
Simon / APP Team
#7 Posted : Tuesday, May 21, 2013 4:12:10 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
