louisechas@aol.com
#1 Posted : Monday, May 13, 2013 3:38:39 PM(UTC)
louisechas@aol.com
Icemaker Makes Ice Only Infrequently. If I Move The Full Bar Forward It Will Make One Cycle.
I Put Ice Cube Trays In And They Freeze Quickly.
Any Thoughts?
#2 Posted : Monday, May 13, 2013 6:39:59 PM(UTC)
What did you call "Full Bar"?
The model number you posted does not come up. Verify and repost it please.
louisechas@aol.com
#3 Posted : Wednesday, May 15, 2013 6:21:07 AM(UTC)
louisechas@aol.com
model is PSS26SGRCSS
Joe / APP Team
#4 Posted : Wednesday, May 15, 2013 8:33:10 AM(UTC)
Joe / APP Team
Loise, "If I Move The Full Bar Forward It Will Make One Cycle." indicates an issue in the ON/Off lever mechanism or the tension spring between the "paddle" and the base of the control module(front of ice maker) You may want to check That first. There are no repairable or replaceable parts, and the ice maker will need to be replaced
Part number: AP4345120
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
ICEMAKER ISSUE: Kitchenaid KSRS27QFAL00 Superba (Refrigerator & Freezer Repair)
by jselko 10/14/2023 1:30:11 PM(UTC)
Icemaker for Kenmore 106.51764510 (Forum Announcements)
by jzannini 9/26/2023 12:37:24 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
GE Undercabint Icemaker (Refrigerator & Freezer Repair)
by rjcunning 4/9/2023 7:35:53 AM(UTC)
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
New icemaker failed (Refrigerator & Freezer Repair)
by 7Pat 12/18/2022 11:40:20 AM(UTC)
Buy (200 Pcs) New Insignia - 44 Lb. Portable Nugget Icemaker $39,800 (General Talk)
by eikohajime30 11/9/2022 10:16:55 PM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
